Ok guys, so as mentioned i have an 07 650 prowler with weak/no spark.
I have about had it with this machine to be honest. I’ve done the following
Changed the plug, coil and boot
changed the cdi, battery, checked all fuses, checked blue coil wire for continuity to coil and short to ground. Checked ground to coil and cdi. Checked 12 volt switched to cdi.
i changed the stator and magneto. I checked the signal to coil at the cdi to confirm i didnt miss a break in a wire or false reading. I’m lost any help would be appreciated!
