Starter problem serviced by dealer. They cleaned the ground wires and installed a new battery. Starts OK now.
Got it home and the speedometer does not work. When key is activated the needle moves slightly counterclockwise. I checked for broken wires connected to the speed sensor at the transmission. I probably will pull the dash tomorrow. Any help appeciated.
Speedometer is around $300 without the sensor.
Tkx, Mike
I'm having speedo issues myself. I have found that the F-ACC fuse under the driver's seat is the culprit. I am not sure why it keeps blowing the fuse, though. I have put a meter on it and with engine running there is only 10-15 ma through the 15 amp fuse. Would anyone have a wiring diagram for these machines?
