Hey y'all nice to be here
so I'm working on buddies 1000 prowler thunder cat 2009 & his trany craped the bed. Removed engine & removed bottom pan found the gear on the trany shift shaft that meshes with the gear on the shaft with front & rear yokes on it completely striped, both the bottom pan & one side case 1/2 Baddley damaged & the sealed bearing under the big gear that striped has broken, also lots of fine metal & large chunks. (not sure how to post Picts or I would as is very impressive) Now have not priced anything out as of yet but I'm sure the case 1/2's are sold as a machined matched set, so cost wise would we be looking better after replacing EVERY bearing in the whole engine & trany + the case 1/2's & gaskets (also have not taken cylinders apart as of yet to look for cylinder/piston damage from metal). Or do y'all think it's engine time. I know this is not a very unheard of failure so any help/info from those in the know would be muchley appreciated. It's a shame really as it is a very nice looking sxs & in great shape. either way I don't think it should have happend like that as the gear that meshes with the one that is gone has minimal damage (minor nicks) so one would think if they were made of the same metal they should both be hooped, but not the case. Oh and the gears & bearings show no signs of discolour from heat
Discussion Starter · #2 ·
have any of you guys had any help from your dealers if the bike is out of warranty sincce this is a known issue with the 209/2010 1000 xtz's? now that is just a question so dont read anymore into it as I iam a GM tech who is now the service manaqger at the dealershp & sometimes(SOMETIMES)if it is an known issue with a certain modle/brand if it out of the warranty period we may step up & help a customer that fits the right criteria? also I took appart the top end toninght & found there to be some signifigant scoring on the piston skirts & majore/minor thrust sides of cylinders. so from what I can see this 2009 xtz 1000 with 1200km on it after looking at the damage to the bottom aluminium pan, 1 case 1/2(got to buy all 3) the "secondary drive gear" "secondary driven gear" "drive gear" + some other gears EVERY bearing the WHOLE engine/trany assmembley 2 pistons & all(ALL) the gaskets. this poor bastard needs to buy a new enginge/transmission assembley as it is not worth the amount of parts I need put into it to get it back to as good as it was before this happened. with absolutley no gaurentees that it will not do it again.... unless he buys a new "upgraded" engine as arctic cat has "fixed" the known issue with these ones. Not sure what the rest of the world is like as I said im from GM land but if I did not step up & help out a customer that was looking at $5,000 in just parts on a $14,000 car 1,200km into its life im pretty sure ther e would be a whole lot more other brands of cars out there & I would be looking for work. sorry about the rant but Im all about the customer service & wowing the customer even if it costs me money at the end of the day as for every one that costs me money I make it back on them cuz there now loyal & be back for maintance & they tell all there friends about the customer service they got at my shop so now they come to me too! not only does it make sence IT WORKS VERY VERY WELL
