Does anyone know how to bypass the reverse override in a 2007 650H1? I can jump the switch and get full reverse in 4 wheel drive,but not in 2 wheel drive.Can it be defeated with the stock computer? Any help is appreciated.....
On the console,jump the 2 wires on the override switch together.Now,this alone will only work the first time,as the cdi box is looking for the signal EACH TIME you go into reverse.To defeat this,remove the seat,and facing the center of the machine,the 4th wire from the right side ,top row is a blue wire with a white stripe.This is the wire that tells the cdi you're in reverse.On mine,I checked first to make sure it shows 12 volts when put into reverse,then disconnected it from the plug and taped it off.Hope this helps......
