2007 650XT
When I turn the key on, the neutral light doesn't come on, and it won't "crank" the engine while the key is in the starting position. If I jump the solenoid, the engine cranks fine, starts, and then the neutral light will turn on once the motor is running. Once I shut it off, I'm back to square one once I try to re-start.
I installed a new battery in the unit, foolishly not diagnosing the original "not turning over/ no neutral light" issue.
My first guess is the key switch might be toast, but is there something else I should maybe look at before I start buying parts?
Any suggestions are appreciated - thanks!
