Good day all cat users
Last night we were out on the prowler
It was - 15 Celsius, had dinner at the warming shack, when it was time to leave , I turned the key and had no dash lights, no brake lights, no aux power for light bar.
Had headlights and tail light. I jumped the start solenoid and had lots of battery. I wiggled the relays and no change. We started to tow it and half a mile away it came to life again. Also noticed the past while the high beams drop out randomly.
Wondering if this has happened to anyone, also if there maybe a common issue with this rig. Any help is appreciated.
Check all electrical connections, clean and apply dielectric grease. With everything out, and a good battery, I'd check the main fuse for corrosion or loose wire. Usually the electrics are pretty reliable on the 700 XTX.I have the same machine, and whenever I unplug a connector I clean and grease it
