I acquired a non running prowler the person i got it from replaced the engine with a unknown different engine and could not make it run It has no spark I have been though every test i could find in the manual the OHMs on the Crank position are correct but the voltage out while cranking are low so i looked at the number on the flywheel it is 0802-059 that by looking up in for a newer machine could this cause a problem Thank you for your time
