This bike was running great until it wasn't. Out for a trail ride and stopped to rest. Shut the engine off with the key, when I went to start it back up it would not start. Everything came on like normal and the engine would turn over. You can hear the fuel pump running and you eventually smell fuel.
One year later, new cdi, new stator and it is still not running. Any ideas would be great!
Download a free service manual at Country Cat.
Problem: Engine will not start or is hard to start (Compression too low) Condition Remedy 1. Valve clearance out of adjustment 2. Valve guides worn - seated poorly 3. Valves mistimed 4. Piston rings worn - broken 5. Cylinder bore worn 6. Starter motor cranks too slowly - does not turn 1. Adjust clearance 2. Repair - replace guides 3. Replace camshaft 4. Replace rings 5. Replace - rebore cylinder 6. See Section 5 Problem: Engine will not start or is hard to start (No spark) Condition Remedy 1. Spark plug fouled 2. Spark plug wet 3. Magneto defective 4. ECU defective 5. Ignition coil defective 6. High-tension lead open - shorted 1. Clean - replace plug 2. Clean - dry plug 3. Replace magneto 4. Replace ECU 5. Replace ignition coil 6. Replace high tension lead Problem: Engine will not start or is hard to start (No fuel reaching the fuel injector) Condition Remedy 1. Gas tank vent hose obstructed 2. Fuel hose obstructed 3. Fuel screens obstructed 4. Fuel pump defective 1. Clean vent hose 2. Clean - replace hose 3. Clean - replace inlet screen - valve screen 4. Replace fuel pump Problem: Engine stalls easily Condition Remedy 1. Spark plug fouled 2. Magneto defective 3. ECU defective 4. Fuel injector obstructed 5. Valve clearance out of adjustment 1. Clean - replace plug 2. Replace magneto 3. Replace ECU 4. Replace fuel injector 5. Adjust clearance Problem: Engine noisy (Excessive valve chatter) Condition Remedy 1. Valve clearance excessive 2. Valve spring(s) weak - broken 3. Rocker arm - rocker arm shaft worn 4. Camshaft worn 1. Adjust clearance 2. Replace spring(s) 3. Replace arm - shaft 4. Replace camshaft Problem: Engine noisy (Noise seems to come from piston) Condition Remedy 1. Piston - cylinder worn 2. Combustion chamber carbon buildup 3. Piston pin - piston pin bore worn 4. Piston rings - ring groove(s) worn 1. Replace - service piston - cylinder 2. Clean chamber 3. Replace - service pin - bore 4. Replace rings - piston Problem: Engine noisy (Noise seems to come from timing chain) Condition Remedy 1. Chain stretched 2. Sprockets worn 3. Tension adjuster malfunctioning 1. Replace chain 2. Replace sprockets 3. Repair - replace adjuster
