The newly released and tweaked 2011 Arctic Cat Prowler is out and better than ever! The new Prowler XTZ 1000 received some much needed adjustments to look and handle sportier. Equipped with a 1000cc V-Twin, SOHC, 4-stroke, 4-valve w/EFI power-plant, this bruiser might just have the moves it needed to become king. The all new 2011 XTZ 1000 also comes in two new color combinations: White Metallic or Viper Blue Metallic. A few other new improves to note, is the newly added Power Steering, 2'' receiver hitches front and rear, standard rearview mirror and a deluxe digital/analog gauge. There are several other visual goodies, such as the redesigned roll cage, with several new safety features to help keep the driver and passenger safe, while still looking aesthetically pleasing.
The jury is still out whether Arctic Cat's new revision of the Prowler is now a top contender until we actually drive this beast, but the new changes make us feel as though a title shot is in order!
Find more photos and info about the complete model lineup over at UTVBlog.net
SPEC SHEET:
ENGINE
Displacement - 951 cc
Engine Type - V-Twin, SOHC, 4-stroke, 4-valve w/EFI
Bore & Stroke - 92 x 71.6 mm
Cooling System - Liquid with fan
Fuel Capacity - 8.2 gal / 31 l
Alternator Capacity - 25.0 amps
Speedometer - Analog
Odometer - Digital
POWERTRAIN
Transmission - Automatic CVT with EBS, Hi/Lo Range and Reverse
Drive System - 2/4 WD + Electric Diff Lock
Front Brakes - hydraulic disc
Rear Service Brakes - hydraulic disc
SUSPENSION
Front Suspension - Double A-Arm
Front Travel - 10 in / 25.4 cm
Rear Suspension - Double A-Arm
Rear Travel - 10 in / 25.4 cm
Front Tires - 27 x 9-R14
Rear Tires - 27 x 11-R14
DIMENSIONS
Overall Length - 118.75 in / 301.6 cm
Overall Width - 61.5 in / 156.2 cm
Overall Height - 79 in / 200.6 cm
Wheelbase - 75 in / 190.5 cm
Ground Clearance - 10 in / 25.4 cm
Dry Weight - 1315 lbs / 595.7 kg
TOWING/HAULING
Underhood Capacity - 25 lbs / 11.34 kg
Rack/Box Storage Capacity - 600 lbs / 272.15 kg
Towing Capacity - 1500 lbs / 680.4 kg
SPECIAL FEATURES
Power Steering, Cargo Box Rails, Gas-Charged Shocks, Mirror, Aluminum Wheels
SUGGESTED MSRP - $15,599
