2012 ARCTIC CAT TECHNICAL SPECIFICATIONS
ENGINE DISPLACEMENT (CC) - 951
ENGINE TYPE - V-Twin, SOHC, 4-stroke, 4-valve
FUEL SYSTEM - Electronic Fuel Injection
COOLING SYSTEM - Liquid
TRANSMISSION/FINAL DRIVE - Duramatic CVT P/R/N/L/H; Shaft
DRIVE SYSTEM - Electric 2/4 WD w/ 4WD Lock
SUSPENSION TRAVEL FRONT (IN./CM) - 17/43.2
SUSPENSION TRAVEL REAR (IN./CM) - 18/45.7
GROUND CLEARANCE (IN./CM) - 13/33
SUSPENSION TYPE – FRONT - Double A-Arm (compression adjustment & reservoir)
SUSPENSION TYPE – REAR - 5-Link Trailing Arm, (compression adjustment & reservoir)
FRONT/REAR BRAKES - 4 Wheel Hydraulic Disc
PARKING BRAKE - Park in Transmission
TIRE FRONT - 26x9R-14
TIRE REAR -26x11R-14
WHEELS - Aluminum
FUEL CAPACITY (GAL./LITERS) - 8.8/33.3
BED BOX DIMENSIONS (IN./CM LxWxH) - 35.8 x 21 x 8.4 in. 90.9 x 53.3 x 21.3 cm
BOX CAPACITY (LBS./KG) - 300/136.1
PAYLOAD CAPACITY (LBS./KG) - 740/335.6
LIGHTING FRONT - White LED, High/Low
LIGHTING REAR - LED, Tail - Brake
ADJUSTABLE STEERING - Tilt Steering Wheel
ELECTRONIC POWER STEERING – Yes
INSTRUMENTATION - Digital Gauge, Analog Speedometer, Odometer, Tachometer, Trip meter, Gear Indicator, Fuel Gauge, AWD Indicator, Hi-Temp/Low-Batt Lights, DC Outlet
WildcatForums.net
