I have a 2012 prowler hdx 700, I'm new to the forum so let me know if I do something wrong. So far the issues I'm having with it are; hard start condition, it will crank and crank but won't fire, sometimes if you fiddle with the gas pedal it will start, and sometimes it will fire right up with no problems so I'm thinking it's something electrical. Secondly, a really weird issue, I have oil IN my coolant radiator but absolutely no coolant in the oil, I'm sure that it's oil in the radiator because I flushed it and then changed my engine oil at the same time and have already noticed the oil level dropping while the coolant starts to get muddy looking. The coolant light will also come on while the engine is idling for a short period of time but as soon as I start driving the light will turn off and it seems fine (I don't have a gauge to see exact temp.) So I'm just wondering if there is a gasket on the water pump that could be allowing oil to mix with the coolant. Besides those issues it runs great. it's got about 3400 miles on it with a new motor at around 2500 miles. Any helps appreciated so if you've had similiar issues let me know how you solved them thanks in advance!
