I own a 2014 Prowler 500cc. I recently went to start it and it would not run. I will say it has had a hard start long crank for a couple of months. Now it won't start at all. It will run on starting fluid. I checked the fuel injector and pump. The pump seems to be working fine. The injector will open and close the solenoid when I apply direct 6 vote to it. I used a multi meter to check the voltage across the injector plug and found only 3 volts.i also checked the resistance in the injector it was a 12ohms Not sure if this condition is normal. I applied 6 volts directly to the injector and pulsed it manually and the machine will run. Is this a cdi box or some other sensor. Any help with this would be appreciated thanks
