NEW FOR 2015
- New closed-loop EFI system with catalyst exhaust provides 25 percent improved fuel economy and lower CO emissions for optimal performance in all conditions.
LEADING FEATURES
- H1 445cc 4-stroke engine with EFI, SOHC and liquid-cooling
- Duramatic Automatic transmission with Hi/Lo-Range, reverse and engine braking
- Electronic 2WD/4WD
- 40/20/40 sculpted seating for three occupants
- 41-in. x 55-in. x 10-in (LxWxD) tilting cargo box with 600-lb. cargo capacity and multiple tie-down points
- 85-in. wheelbase for improved ride and hauling capabilities, but retains same 118-in. overall vehicle length
- 1,500-lb. towing capacity
- ROPS certified Wildcat-inspired round tube canopy
- 10 inches of suspension travel front and rear
- 10 inches of ground clearance
- 2-in. front and rear receiver hitches
- Electronic gauge with integrated seat belt and park light indicator
- 26-in. Duro Kaden tires with14-in. steel wheels
- Available in Red or Green
Three in a Row Make ‘Em Go
The 2015 Arctic Cat Prowler 500 HDX is built to deliver three-occupant adventure and versatility at a premium value.
Built upon the award-winning HDX design, the 500 combines space for three occupants in the sculpted 40/20/40 “bench” seat and is part of a spacious cab surrounded by a ROPS round-tube canopy.
The cab is matched by a versatile rear cargo box that’s designed to haul a variety of payloads. Spacious enough to hold items as large as a pallet, the transformable 2-in-1 composite cargo box design tilts and hauls 600 pounds while multiple tie-down options ease securing those loads.
Power is delivered via the H1 445cc 4-stroke engine with spot-on calibration of Electronic Fuel Injection. It’s matched by the Duramatic Automatic transmission, which features High/Low/ Neutral/Reverse/Park and dynamic engine breaking. The 500 HDX features electronic 2WD/4WD selectable by a dash-mounted switch.
26-inch Kaden tires with 14-inch steel wheels and red or green bodywork are standard.
