Fan circuit for adding the override switch should be easy! Two wires on the temp sensor, one is power from the ECM, and the other is a ground from the ECM. Add a switch to ground on the ground wire to the ECM. Splice a wire to a switch, and then to ground and it should work for you! It will allow you to trigger the relay.
