1 - 8 of 8 Posts
Will a full set of 28"x10 bighorns front/ rear be too big without any clutch mods?
My 650xt is stock. Will lighter rollers help? My rollers are stock 21grams.
Thanks!
You can go down to 18 gram rollers for 28" tires, or the trac spacer kit. Either one will help the low end. I have 28's on mine, and they are about 6 lbs. per tire heavier! The 18 gram rollers are the RED ones from Arctic Cat. See the list below for part numbers
CLUTCH INFO
red rollers = 19 grams = 6000RPM AC # 0823-164
blue rollers = 21 grams = 5500RPM AC # 0823-167
green rollers = 23 grams = 5000RPM AC # 0823-170
white rollers = 25 grams - 4500RPM AC # 3402-483
grey rollers – 28 grams - AC # 0823-295
black rollers – 33 grams AC # 0823-298
17 gram roller - white - 02/375 - 03+400 - part number: 3402-366
19 gram roller - red - prowler 09+700 - part number: 0823-164
21 gram roller - blue - various H1 engines - part number: 0823-167
23 gram roller - green - Tcat engines - part number: 0823-170
25 gram roller - white - 06+ 500 - part number: 3402-482
25 gram roller - white - 00- 09 500 - part number: 3402-483
28 gram roller - gray - 10/650MP - 11+700mp - 12 WildCat - part number: 0823-295
33 gram roller - black - 10+ Tcat mudpro - part number: 0823-298
Discussion Starter · #4 ·
What about 26x9 all way round? I understand I dont need any mods.. But is there any concerns about that? Wont I gain a bit more power? As you understand Im concidering different options for my 4 new 7" rims
26 X 9's have been used. It would free up your power, less rolling mass to overcome. All depends on your riding style. I wish I would have found a lighter tall tire than what I put on mine, but I had to have a DOT (Department of Transportation) approved tire to get in licensed for the street. I'd try 26 X 9's, and I think it would be a great combination with the stock clutch!
When you decide on a tire check some reviews to see if it measures to the full height. My 26" tires were actually 25" when mounted. I think the next time I might go with 27x10 on all four, I haven't decided on a tire brand yet.
Discussion Starter · #7 ·
Yes, I`ve been looking around a lot. At the moment Its the Bighorn 2.0 26x9 all way round I want the most. Also read they are at least 26". Someone also writes that they measure almost 27". Anyone in here who have measured their Bighorn 2.0 26x9?
But there is a drawback with them - either if I buy them in Norway or ship from US it will cost A LOT..
I have a set of Bighorn's. Mine measure right at 26", I run 12 psi on the tire pressure. I ride trails, and hard pack and the wear is great! For an all around tire they are pretty good! Do you have access to any Light Truck tires? I did find several in the states that were 26" tall, radial 215X14
1 - 8 of 8 Posts
