New member!!??
I just bought an 07 650 prowler with 300 hrs, 3400 miles. Mainly used on a farm. It has a real bad drive line chirp/growl. I can feel a little slop in the rear drive line u-joints. They are ordered and will be in on monday (10/21). The noise has gotten worse in the last 30 miles.
It sounds like a hot dry drill bit at 600 rpm while driving 25 mph.
I drained the rear diff oil and only got a puddle that would cover half of a 1 gallon drain pan. No water and no chunks or shavings.
I pulled the drive line and put it up on jack stands. I spun the tires by hand and heard what sounded like a pinion growl. I pulled the input housing ,only to find out I needed a $60 tool to look at the pinion gear. Then I realized that with no resistance on the input, the pinion would rub both sides of the other gear(duh).
CVs sound good, no bearing ticks at slow rpm.
Rear u-joint had a little rough spot but were not dry. I have not pulled the front (of the rear driveline ) u-joint yet. That is where I felt the slop.
The rear drive line through the diff seems like its a good tight.( not sloppy, not too hard to turn)
I do have about 10 degrees of slop at the transmission. Is that too much?
