Hi, new to the forum. I searched for header pipe leak, exhaust leak, etc. and didn't find anything relative to my problem. If I missed something, I apologize in advance. I bought a 2007 Prowler 650 H1 and noticed the muffler was pretty loose. I grabbed the headed pipe and it was moving around where it mounts to the engine. I tightened down to torque spec and it still moved around where it mounts to the engine. I then took it off to check the exhaust seal and can't seem to locate it (if it was ever there). Does the seal sit inside of the engine, or does it seat around the header pipe? Thanks for any help or suggestions.
Jim
Thanks again. I looked at them and will order one. What tool do you use to remove the gasket? It is not exactly easy to get to without removing a bunch of other things. Thanks again.
