basically the manufacture does not have a fix that works or if they do they are not willing to share with us, the fix they had my dealer do for me was a new axle that popped out at 55 mph and I almost rolled with my 5 yr old in the first mile, at that point I wanted to learn what was going on with this problem, an after 3 axle slide outs the last 2 fixes my self at camp with minimal tools, my conclusion is that some machines left the factory without 2 little O rings that help expanded a C clip on the inboard stub axle to keep in place in the diff once it is properly installed , well I went with 4 O rings and seems to be working so far almost 400 miles now and no slide outs,
I'm having some other issues needing attention now like motor firing out of sinc when cold starting and oil leaking out of the water pump , I'm sure it will be the same treatment from factory, my dealer has been great factory not so much , I'll keep you posted on how that turns out
I guess you would expect some problems from a first yr vehicle but I thought they had a few yrs under there belt with the Prowler and same with the Thunder Cat motor, that what I get for guessing
