Hello
i have a 650h1 ,2008 prowler with less than 200klm.
The problem -- the gear shift, when in low the shifter is in the high slot,when in high the shifter is in the neutral slot,when in neutral it is just below the reverse slot and it is hard to get into the reverse slot for reverse.
i have taken the unit to the dealer and they responded with , ther needs to be an adjustment but only after 200klm are on the machine.
Will damage be done by drivining the machine as described? Thanks
