The Hammerhead brand is known to motorsports enthusiasts as the company that designs and manufactures a wide range of aftermarket products for cars, trucks, quads, and side-by-sides. As a sub-division of the Holl-Mac Corporation, the Hammerhead headquarters is located in Bay Springs, Mississippi. The company’s manufacturing facility is ISO 9001 certified, so you can be sure that all the products coming out of the factory are of top quality.
Check out the line of Hammerhead LED lights available at POWERSPORTSiD.com. You can choose the right equipment from the assortment of one- or two-line LED light bars of different lengths and lighting outputs as well as cube lights. Until the end of May, you can buy all Hammerhead products with a 10% discount! Make your darkest night at the trails bright as day with Hammerhead LED!
Hammerhead® - Combo Spot/Flood Beam LED Light Bar (31.5", 21.5")
Specifications:
• Beam pattern: combo spot/flood beam
• LED rows: single/dual row
• Mount type: surface mount
• Material: aluminum
• Shape: straight
• Color temperature: 6000K
Hammerhead® - Dual Row Combo Spot/Flood Beam LED Light Bar (11.5", 13.5")
Specifications:
• LED rows: dual row
• Shape: straight
Hammerhead® - Zilla 7.4" 2x30W Combo Spot/Flood Beam LED Light Bar Kit
Specifications:
• Size: 7.4"
• Watts (per kit): 2x30W
• LED rows: single row
• Series: Zilla
• Material: die-cast aluminum
• Shape: straight
• Amperage: 2.25A
• Lumens: 3300
• IP67 Waterproof Rated
Hammerhead® - High Intensity 3" 2x20W Cube LED Light
Specifications:
• Size: 3"
• Watts (per kit): 2x20W
• LEDs/bulbs quantity: 4-LED
• Series: High Intensity
• Shape: cube
• Raw lumens: 1920
Hammerhead® - High Intensity Flush Mount 3" 2x20W Cube Flood Beam LED Lights
Specifications:
• Size: 3"
• Beam pattern: flood beam
• Mount type: flush mount
• Shape: cube
• Raw lumens: 1920
Click on the image to enter the product page for more information.
Press the "shop now" button to browse the full catalog of Hammerhead lighting products at powersportsid.com
If you have any questions, feel free to contact us here or call 888.903.4348 (toll-free) to speak with one of our specialists.
