I just replaced the battery in my 07 prowler and when I started up the machine the backlights in the cluster went on, and none of the information went on.
I have no speedo, gear, 4x4 tach, or any other information in the cluster.
Has anyone had this trouble after a battery replacement, or any other time?
Premium Member
I Only had that problem when my voltage regulator was bad.
Thanks,
I checked battery charge, 14.46-14.75 volts depending on the RPM. machine starts great even cold. I pulled the dash and checked continuity of all wires and all checked out. Pulled the instrument pod and checked voltages at the connection. I don't know what they are supposed to be but all of them registered a voltage. I had to shift and turn the switches on for some of them to register. Is there a way to check the pod itself or should I just order one.
