Fully loaded with two passengers and a good 8 pt (roughly 600 lbs total) she really struggles with the steep ridges of N. Alabama. Have to handle the throttle like a beautiful lady to keep tires from breaking loose even in 4WD. Using stock OEM tires. Any tips/tricks you guys can turn me on to?
Not worried about top end. Where I hunt, 20 MPH is screaming.:sad2:
You should start by getting a good set of tires. IMO the OEM tires are garbage...Are you using LOW range while climbing these steep hills if you aren't going fast? You can contact ///AIRDAM and have him do his magic to your primary clutch for better low end.
/// Airdam - Home
