eBay Motors: NEW 2009 ARCTIC CAT 700 XTX PROWLER LE SIDE BY SIDE (item 320330764719 end time Jan-15-09 07:48:57 PST)
Vehicle Description
YOU ARE BIDDING ON A NEW 2009 PROWLER 700 XTX EFI LE. THIS UNIT HAS IT ALL FROM THE NEW FLAT BED TO THE TILT STEERING. UNIT COMES WITH A 3000LB WARN WINCH, REAR VIEW MIRROR, ALUMINUM WHEELS AND THE REAR STAKE BED. THIS MACHINE IS AWESOME, HAS PLENTY OF POWER FOR A SIDE BY SIDE 4X4 MACHINE. FREE SHIPPING WITHIN 500 MILES FINANCING AVAILABLE UPON REQUEST.
Stand apart. And above.
Get more done - and look good doing it. The 700 H1 EFI engine can trudge through any task you put before it. The rear flatbed with stake sides, 3000-lb. winch and 2" ball receiver hitch make hauling nearly anything and everything more manageable than ever. And the Cat™ Black Metallic automotive paint and heavy-duty aluminum rims make every glance well worth it.
Specifications
Vehicle Description
- 700 H1 EFI Engine: Race-bred 695cc liquid-cooled EFI features a single overhead cam and a single cylinder. The "H" stands for its hemisperical combustion chamber, which delivers more efficient combustion resulting in better performance. Electronic Fuel Injection ensures easy starts and consistent performance in various climates or altitudes. Push the throttle with this one, it answers big-time.
- New 14" Machine Aluminum Rims: Newly styled heavy-duty polished aluminum rims with painted black inlays. These sporty rims will grab attention and won't let go.
- Electric 2WD/4WD and Front Differential Lock: When the going gets tough, electric shift allows the rider to shifft from 2-wheel drive to 4-wheel drive on the fly with just a push of a button. For maximum traction, activate the front differential lock. Simply stop, pull the lever, and work you way out.
- Turf Saver Differential: The Detroit Locker differential is designed to unlock as you turn the vehicle. It allows rear tires to rotate at varying speeds to avoid damaging your lawn. When the going gets tough the locker engages to provide traction to both rear tires.
- Towing Capacity: With a receiver hitch on both front and back, this machine is rated to tow 1500 lbs. So go ahead, launch your fishing boat, move that snowmobile trailer, or haul hay, wood, building or landscaping materials with one of our 2-wheel cargo trailers.
Specifications
- Displacement (cc): 695
- Engine Type: SOHC, 4-Stroke, 4-Valve
- Bore & Stroke (mm): 102 x 85
- Cooling System: Liquid w/Fan
- Transmission: Automatic CVT w/EBS, Hi/Lo Range & Reverse
- Drive System: 2/4 WD + Electric Diff Lock
- Overall Width (in./cm): 60.0/152.4
- Overall Height (in./cm): 77.5/196.9
- Overall Length (in./cm): 118.5/301.0
- Wheelbase (in./cm): 75/190.5
- Suspension Travel — Front (in./cm): 10/25.4
- Suspension Travel — Rear (in./cm): 10/25.4
- Ground Clearance (in./cm): 12.5/31.7
- Suspension Type — Front: Double A-Arm
- Suspension Type — Rear: Double A-Arm
- Front Brakes: Hydraulic Disc
- Rear Service Brake: Hydraulic Disc
- Tires — Front: 26x9-14
- Tires — Rear: 26x11-14
- Max Fuel Capacity (gal./liters): 8.2/30
- Rack Capacity — Front (lbs./kg): N/A
- Rack/Box/Flatbed Capacity — Rear (lbs./kg): 600/272
- Under-Hood Capacity (lbs./kg): 25/11.4
- Towing Capacity (lbs./kg): 1500/680.4
- Alternator Capacity (amps): 25
- Speedometer: Analog
- Odometer: Digital
- Dry Weight (lbs./kg): 1217.3/551.9
- Minimum Operator Age: 16
- Available Colors: Cat Black Metallic Paint
- Special Features: Rear Turf Saver Differential, Tilt Steering
