I turned on the bike. it was running when I shift it to reverse it died on me, I tried to turn on and there was no power. my kill switch is on and still no power.
it happen to me before twice when i try to turn on there will be no power then when i remove key and put it back in it will turn on.
but now there is no power at all even if i remove key and put it back in
connection to relay is good. battery is new. not sure what could cause this problem.
please help.
thanks.
I had the same issue on a new 2006, had same problem found that they had not installed a ground to the engine block. Every time I used the shift lever it would die, found the problem after dark, when I tried to start the engine it looked like fireworks going off.
