Discussion Starter · #1 · (Edited)
Hi : Removed my belt cover and everthing was good and dry , I removed the rear most clutch to inspect , all good . well then i started up the buggy and reved it up a couple times an well chit oil started to come out around the shaft and dripped on the ground , Well what did i just do , do u think if i install the clutch it will be ok , or do i need to tear down and repair , ur thoughts oh ya its a 07 650
tks Raz
Banned
Sounds like the fixed drive spacer came out. Should be able to slide it back on. But make sure to line up the slots in the spacer to the oil holes in the shaft.
rlaurent,I would say your right,I have heard of that happening.
