My 2009 700 XTX has about 2300 miles. When it had 1900 miles, the temp showed 168. The reading has a blinking hour glass next to it. I assume this is the max temp reached.
Now at 400 miles later, it's reading 187. Seems to increase about 1 degree after each ride.
I've changed the oil per specs. Antifreeze is topped off. Radiator fins are sprayed off and inspected after each ride. Suspected problems are:
1. Radiator cap is starting to fail
2. Fan is starting to fail
3. Spark plug is out of tol
Anybody know Normal Operating Temperature temps? I ride at 5,000 - 8,000 feet. Outside temps have averaged between 75 - 90 degrees.
