Top end is easy to do, cylinder can be finished honed if the plating is intact. Only special tool I used on mine was the Ring Compressor (need the type that unfastens from the handle), these are roller bearing motors so a means to remove the bearings is needed. The bottom end is where it is a little more complicated, you have to split the case to remove the crank, and rod. It is a assembly that can be replaced. I found a lot of used parts on Power Sports Nation, and they do have an 08 700 Prowler scheduled to be available for parts soon. New engines run about 3,200 dollars, used are about 1,900. The advantage of a new engine is: all updated parts, comes with clutch, belt, and covers, warranty, just add your EFI and go, disadvantage : Cost, Cost, and Cost
