21 - 25 of 25 Posts
Premium Member
If The Idle is too high it will not shift high idle can be because of a bad Idle control or othe issue you can try and disconnect the battery for at least 15 minutes then restart and let it idle for a couple of minutes and see if it helped.
Thanks all for the tips. I disconnected the cable at the gearbox end and could get the trans to shift manually (when tapping the gas) The cable was sticky when shifting while it was disconnected, after inspecting it closer I noticed the inner cable was rusty and in poor shape so I've ordered a new one! I'll let you know if this fixes my problem!
21 - 25 of 25 Posts
