That happened to me with both stock rear shocks. What I found was with the extra weight in the rear the back end sags down and the shocks are almost parallel with the ground at compression. That stresses the top of the shock and it breaks under duress.
At first I bought new shocks only and moved the old coils to them. Never again, what a hassle. Then I bought those yellow after market springs that are supposed to raise it up. Nope, not one inch higher. Less than 10" GC. Stock is 13".
I ended up buying a set of Walker Evans shocks made for a 4 seater. Imagine my surprise when I lowerd it down off the jacks and found the rear end was sagging just like before, worse, only 9 1/2" of GC under the frame.
I called WE and asked tech questions, like preloading the coils to raise it up. No, don't do that, destroys the ride.
So I finally bought a 2 1/2" lift kit by EMP and only installed the rear part of it. That brought everything back up where it belongs, the shocks get moved out a little farther from the frame for a more vertical geometry, and it rides awesome. But, talking $2,000 later.
The ride with the WE's was great from the start, built so much tougher. But the sagging rear end bugged me, I was hitting pretty small rocks on the trails my buddies were clearing.
If the ride wasn't also an issue and I had to do it over for much less money, I would have bought the new shocks only ($20 each), put the yellow coils on it ($300/pair? and a PIA to install) and put the EMP lift ($200) in the rear. I think pushing the top of the shocks out improves the geometry and would have prevented breaking more shocks.
Another issue I had with the WE shocks is the reservoirs are on the side. I run wheel spacers but the reservoir still hit the tire when on top. Now I run it on the bottom turned inside the wheel. I can still reach the ride adjuster. WE recommends it turned down to the inside towards the ground that I found that scary with the rocks I run into.
So my expereince with stock Prowler shocks anyway. Hope it helps you decide how to fix the problem.
