UTVCRAP fab shack
2556 Views 4 Replies 3 Participants Last post by  Johnny
Hey That's looking nice Johnny!
2 Fab Guys 1 Machinest 1 machanic and me...and we cant keep up
we had bought a Baileigh 175 tube bender about 6 months ago and the thing has worked flawless so I they were my first choice when needing to upgrade other tools
Press Brakes | Tubing Benders | Tube Bender | Tubing Notchers | Roll Benders | Cold Saws | Band Saws | Tube Bending Equipment
anyhow sorry we have been so busy I didnt have time to tell you what the deal was ... yesterday our new shear showed up it will cut 60" wide 10gage steel our old on only cut 16 gage 48" inch wide so this thing will help out alot on sheet metal roof we had to cut by hand before and now we cun cut custom gussets and tabs ect if we need to..
The SH-6010 hydraulic shear has a 60" wide cutting capacity to accommodate most sheet metal applications. Using powerful industrial grade hydraulics and a solid electro welded metal plate construction, this machine is capable of smoothly shearing through 10 gauge mild steel and 13 gauge stainless steel. The smooth movements extend blade life.
This hydraulic shears upper carriage is heavily built to minimize any deformation and the upper and lower blades have multiple shearing edges, both extend blade life. The operator has the controls to jog the upper carriage, produce one cut with one foot pedal push, or remain in an auto mode by holding the foot pedal down. Hold downs clamp the sheet solidly to the in feed table so the material doesn't lift when being sheared.
Like all other Baileigh Industrial metal shears, this one has been build to withstand years of service. The SH-6010 hydraulic shear is the perfect machine for any fabrication shop.
new tool number # 2
is our new Brake it will handle 12 gage 72" wide as or old one was 16gage 48" wide so when we wanted to bend the little 1" lip on the front of the Prowler or Big Red roof we had to leave the shop and borrow a buddy machine to do it ...
The BB-7212 sheet metal bending brake is a 72" box and pan style brake that can be used as a straight brake or can be configured to make up to 6" deep pans utilizing a combination of 17 varying sized hardened fingers. his sheet metal tool is built very heavy weighing in at almost 2500 lbs and can easily bend up to 12 gauge thick mild steel or 16 gauge stainless steel. The apron is rigidly supported by a heavy duty truss rod system that eliminates any deflection throughout the span of the apron within the guaranteed capacity.
The effort the operator has to use is minimized due to two heavy counter weights that help lift the apron that rides on lube for life precision bearings, which increases production and accuracy of the bend. A positive stop rod system is employed when multiple repeatable bends are required. Like all Baileigh sheet metal equipment, the BB-7212 comes with a rigid bending stand that is the proper height to increase production and reduce operator error and fatigue.
Like all Baileigh Industrial sheet metal forming equipment, the BB-7112 sheet metal brake has been over engineered to offer decades of quality bends in mild steel, aluminum and sheet metal. The BB-7212 is the perfect metal bender for small, medium or large fabrication shops where straight bends or box and pans need to be fabricated. Our sheet metal brakes are backed by Baileigh's unsurpassed quality specifications carried out through both design and production, which offers its operators the best value for the investment. Baileigh Industrial sells its quality metal bending machines throughout North America and Western Europe.​
See less See more
