Discussion Starter · #1 · (Edited)
Does anyone know of a manufacture that makes seals for the wheel bearings on a 2007 prowler 650 just installed new wheel bearings last month and after two rides they are full of mud and water my bearings are the double radius type. Any help would be greatly appreciated.
Looks like later models use a different bearing, but not sure if the new one would fit your knuckle. Have not ran across any seal kits for the wheel bearings. Other option is to upgrade your knuckles, but then you are running up the cost! 500.00-600.00 dollars to convert, and mud and water would still be a problem! No good solution that I know of, others may help!
