Hello everyone.
Last weekend I picked up a new 2010 XTZ 1000. It had 5 miles on it from test rides when I left the dealer. Since then, I have drove it around the farm, and from one farm to another. Wednesday night, I was going up a hill in low range 2WD, and punched it to try to get to an open gate before the livestock did. The rearend started "popping". It was more like a "ratcheting" sound/motion. Neither rear tire spun, but it wasn't going anywhere.
Upon getting back to the house, I held the brake from a stop, and brought the engine speed up slightly. The driveshaft was turning (banging when it tried turning) but the axles didn't move. Normally I would chalk this up to the pinion slipping on the ring gear. I pulled the fill plug, and the oil is definetly full of metal specks. I didn't see any large pieces, but you can't really see anything through the fill hole and you are looking at the back side of the ring.
I just pulled up the parts fiche and I see there is a clutch of some kind connecting the input shaft and the pinion. Is that a plate clutch system, or a ratchet style?
Either way, its under warranty and going to the dealer to be looked at. However, I am trying to figure out what might have went wrong.
Discussion Starter · #2 ·
From further research, it seems its the "spike load dampner". Pretty shitty idea. Why not just build the parts to hold instead of putting a clutch that is already slipping within the first 100 miles?
you can weld it or pin. but the reason for the dampener is the cases aren't quite strong enuff to hold the torque. the 2011 have a upgraded dampener that can withstand more load. We run them in our prowler and thundercats that we mudbog. Holding up really well.
